Anyone use Dremel tools for carving?
I want to do some 'spoon' and small 'bowl' carving.
I have a Dremel and want to try using this for carving.
Don't want to spend any more than I have to.
thanks all
I have used a Dremel for carving and still do occasionally, however I don't like to use it because of the dust. For spoon carving I much prefer a scorp and sandpaper.
Don R
If it's a dremil rotary tool they are weak ,don't stress(dog it) the motor they will burn out in a second.Make your own flap sander with cloth sandpaper strips and a bolt ,washers and a nut.I have a large 6" one for heavy knock down with a 3/8" bolt 6" long.Probably an 1.5 thick with sandpaper 6" round.I use my battery drill to power this,perfect for bowls.I think it's 80 grit.
I do a lot of carving with a Dremel. It isn't a strong tool so you do have to take your time. I don't have unlimited funds so make do with what I have...no hurry...so just poke along. I did get the hand tool with a flexible cable. That makes it much easier to use. The Dremel also makes a great drill, with the router base, for making straight holes for fret work. The flower in the link was completely carved with a Dremel. Sorry for not posting it directly...too much trouble from a Chromebook!  https://photos.google.com/photo/AF1QipMKCOxZQm50by7mgXXAFSNkztKXdvRX-tdmuS9Y
Edited by EarltheScroller
I got an error  on your photo....could not see it.
I have a "Mastercarver" rotary tool that works similar to the Harbor freight tool linked to.  It cost about $300 more than that one and works well for carving.  If I was on a limited budget I would try the one mentioned, from harbor freight.  My master carver  also has an handset that works like a mini jack hammer with gouges and actually cuts the wood with a gouge, rather than grind it.
I use a Dremel rotary tool with a flex shaft and double cut carbide bits for carving. I have had no problems and not a weak tool. I use it for doing Intarsia. I wish it would burn out and then I go u 'd buy a Foredom.
I also use small sanding drums for it. I do carving and sanding over a small down draft table.
I have 3 dremels I use for "carving" and sanding my intarsia. 2 of them have the flex shaft. Each one has a different type of carving bit in them and one I keep a sanding drum in. They work great and don't have any issues with them being WEAK, they do get a workout most of the time and no problems for me. They save me a lot of time trying to carve or sand by hand the tight spots my drum sander can't get into.
