I recently had the opportunity to go through a woman's garage who's father was a woodworking hobbyist. She was letting stuff go very cheap as she was just trying to get the house cleaned out. I walked away with the whole lot for $425, not shown is the brand new little giant ladder. I haven't used or even been around a jointer since high school, so my next project is to get that thing cleaned up and squared off. Any advice on getting the jointer and old drill press up to running like new? They both work but definitely need some buttoning up, and I have never tried to bring an old tool back to life.
I did not get the dog in the garage😁 but I had to show off the new puppy as well!
 Both machines can take a lot of time and tools. If you decide to tackle this start looking up shops that can resharpen joiner blades or supply a new one. If the blade is still sharp you can cut yourself deep, so be very careful moving the joiner guard or removing the blade. I looked up both areas of restoration for you to look at, joiner and drill press. After looking at a few you may just sell them. RJF
https://www.youtube.com/results?search_query=jointer+restoration&sp=CAM%3D
https://www.youtube.com/results?sp=CAM%3D&search_query=drill+press+restoration
Why, I have that same Joiner and have been using it for probably 35 years without any problems at all, I still use almost daily. It is not easy to set the blades but once you get the process down it's not a problem. Depends how much patience you have, Just like all woodworking.
Looking at the picture the front bed looks rusted. So the machine has been exposed to moisture. I can only guess is inside shafts, nuts, bolts, adjustment have rust or are frozen. The Youtubes are a set of refurbishing for removing rust, debris. May need to measure and make sure the bed is flat, is it pitted? I guessed from the picture and not hands on. She can follow as much of the videos she likes. Some of the videos have a few tools and power tools. That's an investment if she doesn't have those tools. Or she can use it as is. RJF
I would have bought those things in a heartbeat if I had the opportunity! Looks like a great deal to me, but I am a retired Maintenance Mechanic/ Machinist! I don't run from a slight challenge.
Karl
12 hours ago, JimErn said:
I would have bought them all too, lucky you, the restoration is therapy, put on some music
That's the plan. When I make it home from the business meetings tomorrow, I'm turning on the speaker and digging into the jointer.
Thank you
