JessL Posted April 19, 2023 Report Posted April 19, 2023 Been seeing the FD Polar blades mentioned a lot in these forums. I would like to give them a try. Do you have any pros and cons to share? Where are you all purchasing these from, besides Amazon. Want to support small business if I can. Thanks OCtoolguy 1 Quote
dgman Posted April 19, 2023 Report Posted April 19, 2023 I use FD Polar blades for cutting compound projects. They are a skip tooth blade with no reverse teeth. They help clear out the saw dust from the kerf for a cleaner cut. Since they are not a reverse tooth blade, they will leave fuzzies on the bottom of flat work, but on compound cuts it doesn’t matter as the outside pieces are discarded. OCtoolguy, Jim Finn and JessL 1 2 Quote
Wichman Posted April 19, 2023 Report Posted April 19, 2023 I get my blades from either; Mike's Workshop https://mikesworkshop.com/ or The Wooden Teddy Bear https://woodenteddybear.com/ ( it's the same company ) Both are listed in the resources page. Roberta Moreton, Moocifer Joe, ChelCass and 3 others 4 2 Quote
Sycamore67 Posted April 19, 2023 Report Posted April 19, 2023 I use a skip tooth blade for cutting thick or hard wood. The skip tooth design allows better clearing of the sawdust and faster cutting than reverse tooth type blades. The FD Polar is this type of blade. Other companies make skip tooth blades also. The expensive PS Woods Super Sharps are another one As with any blade, when you change to it you will need some time getting comfortable with it or maybe uncomfortable with it. OCtoolguy and JessL 1 1 Quote
dgman Posted April 19, 2023 Report Posted April 19, 2023 6 hours ago, Wichman said: I get my blades from either; Mike's Workshop https://mikesworkshop.com/ or The Wooden Teddy Bear https://woodenteddybear.com/ ( it's the same company ) Both are listed in the resources page. While it’s the same company, if you order directly from Mikesworkshop.com, you get free shipping on blades OCtoolguy and JessL 1 1 Quote
Jim Finn Posted April 20, 2023 Report Posted April 20, 2023 On 4/19/2023 at 9:17 AM, JessL said: Been seeing the FD Polar blades mentioned a lot in these forums. I would like to give them a try. Do you have any pros and cons to share? Where are you all purchasing these from, besides Amazon. Want to support small business if I can. Thanks I like them because less downward pressure is required while cutting with them. JessL 1 Quote
JessL Posted April 20, 2023 Author Report Posted April 20, 2023 I ordered some FD Polar blades yesterday. Excited to give them a try!. Quote
Scrappile Posted April 21, 2023 Report Posted April 21, 2023 One of my main blades of real intricate cutting where I really need control. They are slow compared to more aggressive blades so have patience. JessL 1 Quote
