JimNC Posted November 14, 2024 Report Posted November 14, 2024 I just got into Intarsia, and I have been using a Dremel for sanding the edges. So my question has anyone used a router round over bit for this? I have several Dremel tools one set up as a router table. I also have a full-size bench top router table in my shop. For my fingers safety I think the Dremel would be the best option. I do have small parts jig for my full-size routing but that can slow me down. Any opinions/experience with using a router. Quote
barb.j.enders Posted November 14, 2024 Report Posted November 14, 2024 I would think it would be way to dangerous to use a router. I use a flex drum sander, my flex shaft rotary tool, a very small belt sander and hand sanding. On the rotary tool, I often use the thin, flat sanding discs instead of the drum. It seems to offer more control for rounding edges over. ChelCass and MarieC 2 Quote
FrankEV Posted November 14, 2024 Report Posted November 14, 2024 Most pieces are too small, and are often quite irregular in shape with tight points and corners, to use a router on. Then ther is a difference in just breaking the joint edges, or rounding over to make a curved shape. The round-over bit would be too uniform and not produce the curviture needed. I too use a Dremel tool with a wand to do a lot of the sculpturing on the small parts and intricate areas of the larger parts. My go to shaping tools is my Bench Belt Sander and a small bench mounted ocilating spindle sander. I also use a Guinevere with a wand using 1/4" dia shank bits , burrs, and sanding bits on larger pieces when needed. Just my two-cents. ChelCass and Scrappile 2 Quote
Scrappile Posted November 14, 2024 Report Posted November 14, 2024 I think for straight pieces, it would be okay, but for curvy ones, I would be very hesitant! FrankEV 1 Quote
JimNC Posted November 14, 2024 Author Report Posted November 14, 2024 Thanks for the advise. FrankEV 1 Quote
Norm Fengstad Posted December 10, 2024 Report Posted December 10, 2024 years ago a fellow gave an intarsia demo at his home. he used roundover bits successfully all the time. What I got of it is no way am using a router for those small pieces. Quote
Jim Finn Posted February 2 Report Posted February 2 I have been making small crosses for pendants that are less than 2" top to bottom. In order to get into the small sharp corners to round them over I have set up a router in a shop make router table using the smallest round over bit I got from Roxwell. Works well and I think that the bit is so small that one would not get cut if you put your finger into it while running. iI would expect a burn, maybe though because of the speed of rotation. Never got cut nor burned doing this. I run the router on one of it's slowest speed. I have used this on hardwood and on softwood, like pine. Love the results. I have made hundreds of these crosses and have not been cut nor burned once! ChelCass 1 Quote
rjweb Posted February 3 Report Posted February 3 Jim, good to see you back here, how's the inlay box business, RJ danny 1 Quote
Jim Finn Posted March 15 Report Posted March 15 On 2/2/2025 at 7:31 PM, rjweb said: Jim, good to see you back here, how's the inlay box business, RJ It is no longer. I still have about 100 boxes made and found them hard to sell. I have made and sold over 3000 of them over the past 16 years. I was selling at a farmers market and would continue there but the set up and tear down, loading and unloading in 95+ degree weather has become to much for this 82 year old man. I was lifting a total of 1300 pounds every Saturday. (325 pounds four times) I spend my days now in my shop making toys that we (our club) give to local childrens hospitals and other charities. I made, and gave away, 2000 toys each of the past two years. Our woodworking club has dwindled down to about 5 guys at the meetings and I am the only one making toys now. I take some toys to the monthly meeting and we all put the wheels on the toys I bring. I plan to do one sale each September,now but only because my wife needs to sell her crocheted items also. NC Scroller, barb.j.enders and ChelCass 3 Quote
rjweb Posted March 15 Report Posted March 15 Thx Jim, it is still good to see you around, if i take a road trip up north will stop and see you, RJ Jim Finn 1 Quote
