I tried pin nailing a stack again, and again I managed to nail in the wrong spot. At least this time it wasn't on a pattern line and the piece was small enough that I was able to use the scroll saw to cut the pins.
Other than "don't be a dumba$$", how can I prevent this? I had to nail from the back.20241128_092356_092619.thumb.jpg.778e261f2af22aa888d8520d62d10c38.jpg
I almost always use pin nails to hold stacks together. However most times its just blanks for ornaments and being they are almost always round I've not had any issues with just hitting the corners and one half way in the middle of sides and top etc.. I've never done any real large portrait fretwork type where I used the pin nails so that might get tricky as to where to place them at. Back when I was doing that kind of work I didn't have a pin nailer and I just taped around the edges and then sometimes would use wood screws to hold a couple places down in the middle.
For holding projects to my waste board on my CNC router table I cover both the project and the waste board with painters tape and then spray glue both areas and stick it together.. it holds real well so maybe it'd work if you sprayed just one side instead of both.. Doing this on the CNC I want it to hold good but end up having to pry it back up with a screwdriver. Once a corner is lifted it comes up fairly easy, it's just getting it started in one of the corners.
Edited by kmmcrafts
5 hours ago, Fab4 said:
Hey Wich:
Your comment could be a whole new feature here at the Village
Titled:
Don't be a Dumba$$
couple drops of glue in the corners, and on the edges, clamp, then scroll
That would be a popular section in the Village.  I would have a few posts in it.
7 minutes ago, jollyred said:
Why would you nail them from the back?  I first apply the pattern to what will be the top layer.  Then I nail them together in the waste areas.
Tom
I was nailing two pieces of 1/4" oak for the stack. I wasn't sure if the nails would go all the way through and protrude out the bottom of the stack, and then scratch the table. The pattern was applied before shooting the nails, I just goofed up.
As stated by kmmcrafts I also use 2 layers of painters tape but use ca glue, I use this on my cnc router and it holds extremely well, the forces on my cnc router are much more than the scroll saw would generate. You might have to put a layer on instead of a few drops so the spray adhesive for scrolling might work better.
I thought about pin nailing things and always thought it was a bad idea, I would take out probably my bit, blade, and the wood also 🤣
