Sycamore67 Posted December 31, 2025 Posted December 31, 2025 Thought this might be interesting or useful. Klingspor is a great source for everything sanding. ChelCass, barb.j.enders, BadBob and 1 other 3 1 Quote
Scrappile Posted December 31, 2025 Posted December 31, 2025 I use the mac mop on every piece I scroll. It gently remover the fuzzies, and softens sharp corners/edges you want softened. I have the 7" one mounted on my lathe all times except the rare time I decide to turn something. OCtoolguy 1 Quote
BadBob Posted December 31, 2025 Posted December 31, 2025 I have a Mac Mop and the Sanding Mop. I also have the sanding stars. I have not found the sanding stars to be useful. It is possible that I do not know how to use them. I found the Split Mandrel very interesting, since I make this from dowels, and it would be nice to have some metal ones. I did a bit of research and found that these are widely used in making jewelry. I can get them in smaller sizes better suited to my needs. OCtoolguy and Sycamore67 2 Quote
Denny Knappen Posted December 31, 2025 Posted December 31, 2025 Of those, the Mac Mop is my go-to on almost every project. On flat pieces I use the Sand Flee. OCtoolguy 1 Quote
Christian Bergeron Posted January 5 Posted January 5 On 12/31/2025 at 9:33 AM, Scrappile said: I use the mac mop on every piece I scroll. It gently remover the fuzzies, and softens sharp corners/edges you want softened. I have the 7" one mounted on my lathe all times except the rare time I decide to turn something. Good day, i have never a Mac Mop, i would like to use it but i'm scare to break some détails on my project that would ruin my project ? Did you break any details using it ? Thank you for your support OCtoolguy 1 Quote
Scrappile Posted January 5 Posted January 5 53 minutes ago, Christian Bergeron said: Good day, i have never a Mac Mop, i would like to use it but i'm scare to break some détails on my project that would ruin my project ? Did you break any details using it ? Thank you for your support I have not broken anything, BUT, I have mine mounted on my little delta wood lathe and I can turn the rpm down to around 600 RPMs. I don't like sand on grinders because even the slow speed ones are turning at 1750rpm. That is way too fast for my comfort. Other us it at that speed and I have not heard any complaints. I do not apply any pressure when sanding just hold the piece to the wheel and run it over in all four directions. I have used it on some very delicate pieces with no breakage. OCtoolguy and Christian Bergeron 2 Quote
Christian Bergeron Posted January 5 Posted January 5 49 minutes ago, Scrappile said: I have not broken anything, BUT, I have mine mounted on my little delta wood lathe and I can turn the rpm down to around 600 RPMs. I don't like sand on grinders because even the slow speed ones are turning at 1750rpm. That is way too fast for my comfort. Other us it at that speed and I have not heard any complaints. I do not apply any pressure when sanding just hold the piece to the wheel and run it over in all four directions. I have used it on some very delicate pieces with no breakage. Thank you very much, i guess i'll be using it now, it would save me a lot of time . OCtoolguy 1 Quote
barb.j.enders Posted January 6 Posted January 6 15 hours ago, Christian Bergeron said: Good day, i have never a Mac Mop, i would like to use it but i'm scare to break some détails on my project that would ruin my project ? Did you break any details using it ? Thank you for your support This is the sanding mop I use. https://stockroomsupply.com/collections/sanding-mops I have broken some details and had to go searching for bits. Usually able to glue pieces back. For delicate pieces, I would hold a backer on while sanding. OCtoolguy, Christian Bergeron and Scrappile 3 Quote
Scrappile Posted January 6 Posted January 6 I forgot to mention what @barb.j.enders write about holding the piece on a backer or something solid on delicate pieces. I have done that also. Light touch is you put too much pressure on while sanding it can take the piece out of your hand. Christian Bergeron, OCtoolguy and barb.j.enders 3 Quote
