(Remove This Ad)
1 hour ago, JimNC said:
I do a lot of stack cutting. I have tried about 3-4 different brands & types of double and really didn't like any of them. Any suggestions???
My opinion. I do not think double sided tape is a good answer to stack cutting. What I always did was lay blue painters tape on top an bottom and then spray a sheet of copy paper both side with 3M 77 adhesive. That was the way I use to do it. Your milage may vary.
Again I will bring this up. With double sided tape you are leaving a gap between layers which can cause chip out on all pieces. No matter how thin the tape is it still a gap. Everyone is different use different methods but would like to point out some factors.
That is exactly why I like using wood glue.
2 hours ago, TAIrving said:
But be very careful that the wood glue stays in the waste area and does not creep into the pattern area.  Do not ask how I know this.
It only takes a few strategically placed dots of glue. If you use too much glue, that could be a problem. I haven't had that happen yet.
I have tried taping stacks and it works for a couple of sheets, but I am firmly in the clamp and then hot glue the edges.
You just have to avoid getting a bubble of glue below the bottom layer. Trim it off because dried hot glue doesn't slide on v the table. Even the slightest drop will grab your table.
