There are many different ones from cheap to expensive..such as DeWalt, Black  and Decker, Wen, etc.   I have an older DeWalt 1/4 sheet sander which is good.  I love my Festool pad sander but EXPENSIVE.
Personally, I sand mine with a Block sander with 220 paper.  It does a good job for me.  It uses 5" round hook and loop disks with no holes.
I have both a Ridgid and a Milwaukee 5" random orbit sander.  Both connect directly to my 2 1/4" shop vac hose.  The Milwaukee just needed a standard 2 1/4" coupling.  A lot of other ROS require some sort of special adapter to connect to a shop vac hose.
I've had both of these sanders for several years, so I'm not sure if their current offerings still connect directly or not, but I've been satisfied with both of them.
I have Bauer sanders from Harbor Freight specifically because they have round dust ports that can be adapted easily to connect to a vacuum. They work but not near as well as my Hitachi sanders with the weird-shaped dust port. The cords are a bit short and stiff.
Here is what I have without the adapter.
On 12/4/2023 at 4:54 PM, nrscroller said:
Any suggestions on a brand that does.
I only have a BOSC ROS purchased several years ago.
Recently, I took the sawdust collector off to clean it and the filter out out.
In doing so, one rear corner of the sawdust collector cap cracked, (it's a snap fit type cover) resulting in some sawdust being blown out when being used for sanding.
I tried repairing it with JB Weld, but that did not hold.
Checked online for a replacement cover for that model and the cost with shipping was over half the cost of a new ROS.
Later in the day it occurred to me to try using electrical to cover/seal the cracked corner and that works well.  Just have to use a new couple small pieces of tape whenever I clean out the sawdust.
18 minutes ago, Sycamore67 said:
I believe it is baking soda...sodium bicarbonate.  You put down the backing soda over a crack and then add super glue.  it makes a fast very strong joint.
I'm glad I asked. Thanks for the explanation.
Roger that on the baking soda.
I forgot about that - used to repair my carbon fiber propellers when I was flying a powered paraglider and had an oopsie.  Props back then were $600.
thanks for the reminder.
Oh, My,, you are my hero.  We have a few of those flying around where I live... In fact I know one of them is a guy I graduated from high school with.  Looks like so much fun. BUT.  as I understand it wind is an enemy.  We have lots of wind where I live.  So I only see them flying on calm days in the quite evening.  But I look up an envy them.  looks like a lot of fun!
I flew for 15 years and LOVED every flight.  Logged over 1,000 plus hours. Oh, the stories I could tell.
And you are right about the wind.  I was always a conservative flyer.  When I first got into Powered Paragliding I was told and heeded three suggestions: respect the weather, the equipment, and the land you are flying over.
It served me well - I'm still here.  👍
16 hours ago, Sycamore67 said:
I believe it is baking soda...sodium bicarbonate.  You put down the baking soda over a crack and then add super glue.  it makes a fast very strong joint.
I will have to try that on my KitchenAid Meat grinder.  It has a couple of cracks.
Just gotta take my hat off to ya.  Anyone strapping on a paraglider...well, you got more guts than me.  Then strapping on one that you MacGyvered yourself...Man  image.jpeg.a1b545528d2acb061288d81b4850ff1e.jpeg
19 minutes ago, Sycamore67 said:
She says my insurance does not cover me for that.
When I started flying, another piece of advise I got was that if I did have a boo-boo resulting in a hospital visit, it was because:  " I tripped going down the stairs or some such related type of injury - because - Insurance companies could either not insure you or make your premiums very very high.  The word is that insurance companies share such information among themselves, making it hard to obtain/afford insurance.
I blame my wife for getting into that addiction.  She talked me into going on one of them boat pulled parachutes.
My first time being the in the air like that and the view was unlike anything I had seen before.
Not long after, I saw a TV clip of a guy flying a trike (3 wheeler) Powered paraglider, landing with a big grin on his face.
From there, I found a group and instructor and soloed 6 weeks later, getting training on the weekends.
For me the learning curve was high and I was cautious to the point of wearing knee pads for the first two years of flying. And was glad for that one time when I did.
But the view from anywhere from corn stalk tassel high to a mile high - PRICELESS.
But now for fun, I make sawdust.
  • 2 months later...
I too have one that has a crack in it also probable because it's not easy to snap it back on without damaging it... (Great design)
Larry, I tried searching for this block to no avail. Can you help me with a brand name? I tried TP max but no go. I tried TP Tools and got closer but still no go. Help!
Here's one on Amazon  I found it with Google image search. Click on the picture and get just the picture, click on the picture again and another tab opens with the picture, then right click and get the drop down menu with Google image search. :)
https://www.amazon.com/Mesee-Polishing-Woodworking-Restoration-Automotive/dp/B0BKQ1R7WR?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A38WK9AYQDX0WE
I did as you suggested and found a 2-pack with a round & mouse shaped pad for under $9.
